This guide will walk you through the installation of an HKS type 1 turbo timer (In the ash tray). A lot of the information should be useful for any brand of turbo timer as much of the task will be the same. I highly recommend you get a fitting kit with it as it saves a lot of hacking into looms which can be messy.
Note that installing it where the ash tray goes means cutting up the plastic of the ash tray which is some seriously nasty stuff to be breathing in. Well ventilated area and/or a mask would be well worth using for this. Oh, and you don't have to be a genius when it comes to working with plastic - even if you do quite rough cuts they won't get seen because the timer sits proud of any hacking you do!
Step 1 - Remove the two screws shown under the sterring columns
Step 2 - Remove two screws on the other side of the panel
Step 3 - Pull the bonnet release mechanism forward to reveal two further screws you must remove
Step 4 - I found it easier to have access by removing this panel. It simply pulls off
Step 5 - Remove the cover for the steering column by sliding it down towards the pedals. There are tabs along the top (See picture) so you should be careful not to stress anything by pulilng hard/in the wrong direction
Step 6 - Now you can see the inside of the trim you will be able to remove the bonnet pull by sliding it out after lifting the clip shown in the picture
Step 7 - The last thing to do with this trim is remove the light that is housed in the plastic by twisting it and then pulling it clear
Step 8 - Remove the trim from the car
Step 9 - Remove the air ducting by pulling down the right hand side (Picture 1) then easing the left hand side out (Picture 2). There are no clips or screws, simply an interference fit with a foam seal
Step 10 - Locate this large connector for the ignition
Step 11 - Hopefully you will have bought a fitting kit which looks like this. You can see that it will be inserted as a pass-through for the connector shown in step 10 and also produce a flying lead for the turbo timer itself
Step 12 - Press the locking tab on the connector (From step 10) and separate it. Insert the turbo timer's harness in between
Step 13 - You now need to route the flying lead over the steering column and it should come out where my finger is pointing in the picture
Step 14 - Now you have wired into the ignition, you need to route the wires to the ECU and install the timer itself. We move to the centre of the car now and start by removing the ash tray. The second picture shows you the tab you press to pull the ash tray completely out
Step 15 - With the ash tray removed you should see two screws (I only had one), remove these
Step 16 - Remove the screw by the gearstick on the driver's side
