I started tearing apart my 1JZ today in preperation for replacing all of the seals and gaskets. I also plan on going single. I noticed there's a coolant line that goes from the back of the WP housing all the way around the back and to the intake side. I assume this line fed the turbo's and it appears it just goes around to the oil filter housing. What purpose does this line serve on the intake side? Is this the factory equivalent to an oil cooler? Since I'm going to be singling it from the get to I'd like to eliminate as many things as possible that I don't absolutely need. If anyone can chime in as to what they did when going single or when cleaning up their engine bay I'd appreciate it.
