hey guys, i have a brand new competition clutch, stage 4, 6-puck with 104 miles on it. :naughty: the other day i replaced the oil pan gasket (i just took the motor mounts off and jacked the engine up to the max) after that was done, i drove it around for about ten minutes everything was fine. got some gas and pulled out pretty hard and went to shift into second and i heard a bang and it wont let me into any gears now.
i can drive the car, but have to speed shift it
if i start the car with it in gear it creaps forward with the clutch fully pressed down.
i've replaced the master cylinder and rebuilt the slave cylinder and bleed the system 5 times. the clutch line looks fine and there are no bubbles in the system.
any ideas? also there is a horrible vibration at certain rpms :3d_frown:
all input would be great (btw its a 87 na-t, so a w58 trans)
steven
steven
