1jz belt no Ac or Powersteering
Status
Not open for further replies.
Tim
regular member
Oct 16, 2006
272
CA
I am having a very hard time finding a belt for my project car. Its a 1974 260z with a 1jz and I am running no AC or powersteering. I have heard about using the s2000 tensioner pully, but I can't find any more info on what year s2000 tensioner pulley to use, and what belt to use with this setup. I have searched, but have not come up with much. Can anyone help?
Sep 10, 2007
482
Virginia
btw, from what I remember, I had to use a fender washer and grind out the inner diameter a bit to put behind the new ribbed pulley, so it wouldn't rub against the timing cover.
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
yes i don't think it matters what year they are either, i think they are all the same. i did a search on SF and found all my answers from old threads, if you do the same you should be able to find them too
Status
