Wire harness splice
turbogate
Life is Boost
May 18, 2005
425
South, FL
Can someone point me to a company/website where I can get those wire splices?
Thanks
pbasil1
Fully built 1JZ project
Jan 30, 2008
402
Huntsville,AL
I have no clue where to find them. But why splice when you can solder? It will make a better connection, never come loose, or corrode.
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Actually, in many instances in a car environment, crimp connectors are superior. There is a reason why the OEM wire harness aren't soldered, but are always crimped.
At any kind of fixed location where vibration is a factor (ie, most conectors in a car) a crimped connector is better, because it allows for small amounts of motion, which distributes the stress points on the wire. The result is a more durable connection.
Or that's the theory anyway. ;)
turbogate
Life is Boost
May 18, 2005
425
South, FL
That's exactly right :thumbup:
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Heh. I say that, however, seeing as how the crimping equipmeht that I have sucks, I solder all my stuff anyway, then use heat shrink tubing to provide strain relief.
turbogate
Life is Boost
May 18, 2005
425
South, FL
I bought this tool especially for these splices, now I cant find them
