I'm using a 7m w58 with my 1j swap. Which clutch do I need, 7m or 2jzge?
S Sfrench New Member Aug 6, 2010 5 0 0 Kelowna, BC Oct 17, 2010 #1 I'm using a 7m w58 with my 1j swap. Which clutch do I need, 7m or 2jzge?
I<3Supras Drft What do u mean drft? Mar 31, 2005 150 0 0 38 Southern, Ca Nov 1, 2010 #2 Since your using it on a 1jz flywheel and bellhousing i would assume the 2jzge w58 clutch
RockPaperSwoRD I have aCustom User Title Jul 26, 2008 392 0 16 SanAntonio Nov 2, 2010 #3 If youre using the w58 with a jz bellhousing, it will be the same clutch as an n/a mkiv or a 5speed sc300. youll need the 2jzge flywheel too
