Hi everyone i got a question because it happens to be that the trust bearings are missing after replacing pistons,rings,bearings.My motor went out after a month it develop rod knock:nono: .The rod bolts from piston #1 were loose it actually caused the piston and rod to be bouncing a bit.The guy who did everything now claims that nothing would happen but an oil leak only if the trust bearings are not installed. I got into a big argument with the guy that i just wanted to slapp him, so what you think about it guys i will appreciate your advice.
sincere regards David
