Using flourescent oil dye with synthetic oil
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
I've got fresh german castrol in my crankcase and my oil leak has chosen to get a bit faster.
Am I able to put oil dye in my engine and use it to detect my leak, then leave it in for the next 5k-8k miles til the oil change or is this something I should get out immediately after it has served its purpose? should I even be using this (I've tried pressure washing but it hasn't worked out too well)?
jdub
Feb 10, 2006
10,730
Valley of the Sun
Dye is an excellent way to find a leak and will not harm your motor. You can leave it in there till the next change.
Clip
Oct 16, 2005
2,738
9
Virginia
they make dye for refrigerant, coolant and oil. i asked at autozone and they didn't have much of anything, but napa had all the dyes readily available.
Clip
Oct 16, 2005
2,738
9
Virginia
picked up one of napa's bottles of dye (1 oz). there aren't any instructions on the bottle, so i suppose i should just add the entire thing to my crankcase?
jdub
Feb 10, 2006
10,730
Valley of the Sun
That's the point...1 oz is not a heck of a lot in the big scheme of things. Not going to hurt a thing staying in till the next change.
