For some reason my (tps deflection) and the (map analog in/out) flickers all the time. For example, throttle deflection shows 9.8%-75%, then while im driving suddenly it'll bounce 4.7%-9.8%, or it'll jump up 3% and stay there, next time I start the car it's back to the normal def. I had a bad conection before on this 5v signal, but then it would go in to limp mode and send a code. This time its not losing the signal, just changing. So i have an extra 5v input I can monitor but i don't know what pin is sending it so if someone could tell me that would be great.http://http://www.floridasupras.com/wiring-electrical/669-1jz-gte-ecu-pinout.html
Btw its a 1jz
new tps
new map
Btw its a 1jz
new tps
new map
