I'm Curious about the mod in Q.
Hypothetical If I wanted to swap this Mod in And just use a DF 11 Wastegate and put in the injectors, The afm housing, and the 02
Does this call For a mandatory Metal Head Gasket?
I know a lot of ppl throw the Cometic under the bus but, There is nothing wrong with running the cometic with stock setup and the correct torque.
Adding the 3 more lb of boost to the 11 would be interesting.
Has anyone ran a cometic with this mod? If it takes getting the beast milled down I'll look around, but living in the stix makes it ruff.
I am genuinely asking if its safe, short lived, etc.
Haven't found a thread on it.
