Ok just finished my first swap and I go to start it and it wont turn over. The battery light and the check engine light stays on with the key out, I checked the fuse and all are good. dont know where to go frome here? Please help:cry:
1toyotafolife;908241 said:are those the wires the starter?
There is a water hose that goes to the TB and then to the ISC on the manifold. That wouldn't cause it not to start though.1toyotafolife;908955 said:The starter is hooked up correctly ill take a pic of the wires later. Question does the water by-pass hose #3 go on the throttle body?
You need to give us all the info so we aren't playing 20 questions.1toyotafolife;909923 said:It will start like normal but it just wont run!
1toyotafolife;922427 said:Well as of today im up and runnin. It ended up being the distributor cap needed to be turned 180 degrese. Thanks for the help
