Suspension - What Else?
benk777
161
Waukesha, WI
I am currently having a lot of work done to my car (see build thread), but it has been mainly focused on the engine bay. I have decided to also have suspension work done, and have ordered h&r springs, illumina struts, st sway bars, ss traction arms, and ss sway end links. What else do you recommend for the suspension since it will be apart? The car is now 20 years old, and there is no certainty what has been replaced and what hasn't. Let me know what else you recommend, and possibly where I can get them. I did see some aftermarket control arms on ebay...not sure if I need them and if they are of good quality.
Thanks.
Ben
Guyana00
Droppin that JZ in soon!
Apr 18, 2007
1,208
Brampton, ON
Check your ball joints, wheel bearings, tie rods, steering in general. If you don't decide to get poly bushings, check them out and replace with some sort of bushings anyways. Sounds like polys would suit you anyways.
(You can check out the carrier bearing while you're at it,)
