surging idle need help!
ANDR3AS
32
Toronto, Ontario, Canada
88 supra turbo 7mgte idle surges now after trying to lower my idle which was at 3000rpm. i have replaced idle air controller, replaced tps, smoke test to see if there are any vacuum leaks. need help
AJ'S 88NA
2,419
Florida
ANDR3AS;1843270 said:
Only my knock sensor code and I meant lower idle by adjusting it with the tps I put in. And I no it is computer controlled
There's no adjusting the idle with the TPS, it does have to be set and it will effect the idle and the timing. You need to set the TPS then set your timing. http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=FI&P=101 In diag mode the MIL will show code 51 when the gas pedal is slightly pressed and no codes when released. If it does the TPS is set close enough. Never time the engine without first doing this test or at least checking for codes.
