These are the parts the mechanic said i really need to do the 2jzgte (JDM Aristo) swap.
-supra turbo fuel pump inc. stainer, rubber seat and clip - i have a walbro 255 what do i need then?
-supra oem MAF - can't i just use my NA MAF?
-usdm ecu - jdm harness will connect in that but which usdm ecu do i need?
-supra power steering reservior - cant i just use mines?
-supra turbo heater hoses ( 3 pieces + 1 generic hose 1/2")
-sc400 drive shaft and transmission output flange. Also, extra rubber flex coupler
-3" down pipe - cant this be custom?
-custom power steering lines - where do i fine these?
-supra turbo water pump w/housing- sc300 water pump pulley w/supra' turbo pump and housing (smaller that sc300's for clearance)
-supra turbo sway bar w/ end links - supra's oem intercooler piping will not clear sc300's front sway bars. -seriously? well i have an aftermarket intercooler pipeing dose that count?
-supra brak booster vacuum fitting for intake manifold- aristo's intake manifold has a bolt on top of it... toss this and use supra's vaccum booster banjo bolt w/ washers. -the hell where do i find this?
-supra tubo oil return flange, turbo oil return line, return hoses - shit where do i find this? is it really needed?
-supra turbo upper and lower radiator hoses and thermostat housing- why do i need these dont it come with the motor =|
-sc300's a/c compressor is being used. you will need to make a 12VDC. 5A "high sensitivity" relay so your a/c module will communicate correctly with aristo ecu to activate compressor clutch though MGC signal line. - meaning if i have a usdm ecu i have nothing to worry about?
