Stinger v4 not reading RPM
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
Hey guys I am in the middle of wiring up mt stinger v4 to my sc300. I have everything wired up correctly but the car still will not start. I took the base map form the stinger thread with the 62mm and 440s since i have 440s in my car. I saw that he is useing a output for "tacho output" Does that need to be wired in for the stinger to read RPM? If so which wire does it go to?
I tried to wire output 2 to the IGF wire from my stock harness and set output 2 to the "tacho output" on the stinger. The stinger is still not showing a RPM signal. Do any other wires need to be wired in to get the signal?
Thanks for any help.
I will include the jzz30 pinout I am useing to find all the wires.
  • 1JZGTE__JZZ30__pinouts.pdf
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
Ok well after a little bit more reading I have found out that the "tacho output" is for your tach not the stinger to read a tach signal.
So I am assuming the stinger gets the tach signal from the Crank angle sensor wires. I have 2 of them hooked up the Green wire on the stinger Trigger is hooked up to ne- and the red wire 12v+ is hooked up to ne.
This *should* make the tach work right? If I am doing something wrong please let me know.
