Stinger EMS, 1JZ stock coils and MSD DIS-4 compatible???
RacerXJ220
Interdimensional
Abalama
Basically I want to use MSD DIS-4 ignition boxes, but I'm not sure if it will work.
I was going to use just one DIS-4 box, but I might end up using two.
Here's the part that I want to know, will it work using the Stinger with the 1JZ adapter harness? Do I just wire it up normally like the stock ignitor?
If/can I use two DIS-4 boxes, how do I wire it up? Will this help spark? Is it worth it?
Thanks, I know that's a lot of questions but any help here is appreciated.
Jeff
TheNewRed
572
WA
Jeff
The DIS-4 will drive up to 4 seperate coils, so your gonna need a dis-4 and a dis-2 to operate it right. im pretty sure thats what I.J. did when he had his setup. I have a DIS-4 that ill cut you a great price on, if your intereasted(PM me)?
RacerXJ220
Interdimensional
Abalama
I already have two DIS-4 boxes. Come to think about it, I got a lot of extra crap just laying around....
The ignition from the Stinger drive channels 1, 2, 3 respective to DIS-4 channels, but power it's own assigned coil.
DIS-4 (a) = Coils 1, 2, 3
DIS-4 (b) = Coils 6, 5, 4
dogdrake
148
Gadsden Alabama
i think if you configure it to run in wasted spark you could use one dis-4 with the same msd adaptors that the mustangs use . they run one dis-4 on a v8.
