my Mk3 has a 2JZ in it from the aristo, and initially the mighty 2JZ presented some problems with overheating, which has since been resolved with a larger aluminiium radiator and 2 electric fans in it.
yesterday i thought i' wake up turbo no 2 (its still runing on the stock twins), and pushed past 4500rpm.. right then i smelt something strange in the cabin, and moments later, smoke streamed out from the left side of the engine..
i figured one of the hoses must have burst or something. wonder if anyone's experienced this before? this is the 2nd time that coolant's leaked out due to (exscessive?) pressure? the first time it was the lower Rad hose, bound by a stock clip.. u know, the kind that expands when u use pliers to clamp on the ends? i replaced that clip with a standard hose clip/band that is screw tightened, and the prob went away.
i'll jack up the car tomorrow to check for the burst hose.. i'll prob replace ALL rubber hoses in the engine bay with Samco silicone ons... this leaking cooling system is driving me nuts... its making even daily drive a very suspicious affair... sheesh...
any thoughts friends and gurus?
