slow throttle repsonse
mcammarn
matt
Feb 24, 2012
668
olympia wa
so i dont quite know why i have slow throttle response.
just got done doing a head gasket. and while i did that, i replaced 440inj. whith 560inj.
also changed the stock maf to upgraded lexus maf.
i have a aeromotive fpr, but it is not hooked up yet. if anyone knows what size an fitting i need that would be great.
SPOOLINLUST
68
nnj
The one that comes out of the rail I think is a 12mmx1.25 to -6AN. The throttle response check the cable itself may be loose. Check over everything really good vac lines timing ect retrace your steps check your plugs.
ifyouaint1sturlast
Banned Scammer - I'm whitemike.
Jun 14, 2011
480
Fort Myers/Cape Coral - Florida
A good rule to follow for the future is to do one thing at a time. If you fix something big and upgrade something at the same time you don't know what caused the problem.
I personally think your TPS is out of spec, if you didn't touch it then check your timing. Follow the TSRM to check your timing, don't just put a light to it.
mcammarn
matt
Feb 24, 2012
668
olympia wa
what if it could be cps? i had to take it out once i decked the head. but im pretty sure it was put back in the same spot as before.
