sensor question
ma70mkiii
139
ohio
When doing the 1jz swap will the 1jz sensors work with the ma70 gauges or do you have to swap the sensors. Also if you have to swap the sensors do they have to be 7mgte or will ge work? I was just wanting to know before I acually get the engine in the car.
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Oil sensor gauge from the 7m-gte has to be added for that gauge to work. Turbo boost pressure just a vac line from the intake manifold has to be added. Speed will work, Tach will work, gas will work. Also the Temp will work too
ma70mkiii
139
ohio
ok thats cool. not really worried about oil pressure. have mechanical boost guage and and volt meter guage. also have mechanical oil pressure guage for later. thanks
