rear suspension
supraman508
496
maryland
I have a rear suspension fetish.For example,i love when i see the 86 and 87 300 z's that their rear cambers at an angle,meaning that the top of the rear tires cave in and the bottom of the tires stick out.is that for cornering because it looks good.I thier a way to set my rear cambers on my 7mge like that.how much would it be?
Wiisass
So you want more rear camber? Or you want to know how to get more rear camber? Or you want to know if you should run more rear camber?
You can adjust rear camber with the rear lower arms. There are eccentric bolts that will allow you to push out the rear wheels a little. I don't know how much they will adjust, but if it's not enough, then you will need aftermarket arms.
And running a lot of rear camber is not a good idea. You should run a little, but how much depends on spring rates and ride height and what you're doing with the car.
supraman508
496
maryland
the bolts to adjust are the ones with the mesurement meter lines around the bolt?
ideal98supra
Hialeah, FL
yes, those are the ones. But remember more rear camber will cause more tire wear on the inside of the tire. Also, you might not want to run too much rear camber if your suspension is not equipped to do. You will experience less traction under acceleration and your car might start wandering when you are driving due to the rear tires following undulations in the road your fronts do not.
supraman508
496
maryland
cool,i don't wana create to much negative camber.just enuff that i can notice.Thanks for your time and advice.:icon_razz
DegreE
500
Memphis & Miami
What suspension set-up are you currently running on the car?
If its still stock, don't do it... it will look stupid at stock height.
supraman508
496
maryland
The person who had the car before me had it lowered.it's only 2 inches from the top of the tire.
