I have the engine out and I have just finished up cleaning the engine as much as I want to. As I was taking apart the intake manifold, there where signs that had been off before. That is to be expected, but once I had the valve covers off it was obvious that the head gasket has been done before. One of the head-bolts showed some minor tool marks. So instead of just going in a replacing the head gasket as I planned, I decided to chance it and re-torque the bolts. I started at 55lbs-ft and all was secure. Moving on to 65lbs-ft still no movement from the bolts, everything secure. I left it at that.
My question is, should I feel safe with the HG as is? I have not run the engine ever, so no clues other than what is above. Thanks for you advice and expert opinions!
