R154 Transmission ceased on input shaft
raptor7276
5
perkasie, pa
Im a noob to Japanese motors so sorry if I piss you guys off but I need to pull my trans off asap. It just seems to be stuck on there somehow, it looks like the clutch is depressed but its in neutral. Also the bell housing is off about a half inch and is turnable.
The clutch fork is also stuck on the drive shaft. Any help would be appreciated. thanks
mkiiichip
1,434
WI
You need to remove the clutch fork, or unbolt the pressure plate. Its different than most clutch setups. Its called a pull style clutch.
And a drive-shaft is the part that comes out of the transmission, to the diff. Thats probably why no one responded. As this is a common issue.
Clutch Assembly Seized on Input Shaft............not to be confused with Transmission ceased on driveshaft.
Hopefully you get it fixed with the help of Poodles link.
Crank pulley bolt?
There is tools to help with it.
impact will take it off.
Can bump the starter with a 1/2 breaker bar on the ground or frame rail.
I usually break it loose with the trans in fifth and the wheels on the ground.
