R154 rear tail houseing yoke bushing
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
Well turns out I getting some leakage from my rear out put shaft seal and I am thinking that my yoke bushing is worn out
now the question is, can this be changed with the trans in the car and removed with slide hammer and install with a bushing driver
or do i have to pull the tail housing off
thanks
NashMan
Aug 5, 2005
4,940
17
Victoria BC
ya I thinking it's part of the tail houseing
some thing got to keep that shaft steady and the breaing retainer plate is pretty far away so it makes em wounder i am no trans guy thous why I asked
that whould be shitty if i had to replace the tail hoseing :nono:
NashMan
Aug 5, 2005
4,940
17
Victoria BC
hvyman;1738872 said:
Is the seal new?
yes it is
second one I popped in
see there are 2 or 3 things that come to mine
the housing keeps it tight haveing an oil wedge keeping it from touching
or all the aliment is form the retainer plate and snap rings
my splined stub shaft is shorter then reg drive shaft but like mabye 1/4
DJ Aranda
7M-G(T)E Builder
Apr 24, 2012
Tennessee
There is a bushing, you'd have to go to the Toyota dealer to order it.. Part# 90999-73105 (W58). Best thing is that it only costs around $15.. Worst thing is that you need to drop the tranny (unless you really want to pull it out and put that lil thing in under your Supra...) The trouble you'd go through replacing it while under your car would make just dropping the tranny look soooo much easier. Well, hope the # helped. IDK if the part# is the same for the R154 or the 4 speed automatic. If all else fails, check at the dealer. Might cost a lil more, but you end up saving a lot of time, and you know you've got a good part.
DJ Aranda
7M-G(T)E Builder
Apr 24, 2012
Tennessee
If you take your driveshaft out, you can pop out the seal (which you will then have to replace) and look around the tailshaft, you will see those oil grooves like in the bushing I just got. So now you generally know where this thing is in the tranny.. Fun part is getting it out. Good luck. (Remember, this part number is for a W58 transmission, I'm sure of this much.. However it MAY be the same for a R154.. The best advice I can give is check with your local Toyota dealer.. Not "Poodles" ^^^)
