I'm needing to know the advantages/disadvantages in using aluminum connecting rods for a road race engine that will be rev limited to 7500 RPM, and will see an enduro a year. Van
supraguru05;1378676 said:van either get custom titanium rods or use the stock rods shot peened. if you want forged steel rods your options are eagles or the more expensive pauter. you can save significant weight by switching to a 7.5 clutch, and lightening the crank
gofastgeorge;1380025 said:Eagle rods, although not the best choice for an all out turbo 7M, are great for a NA.
They weigh less, they are stronger, come in +/- 1 gram ballanced sets,
and they are dirt cheap.
And if you ever spin a bearing in one, you can call up eagle,
and order a replacement, in a weight that will match your set.
Why bother with the expense of a fully prepped stock rod,
(if you can track down someone th shot pein them)
when for a few dollars more, you can have an H-beam?
By the way, why limit it to 7500?
I turn my NA to 8500 on a daily basis (Eagle rods, Wiseco pistons).
Van;1380209 said:How much lighter are the Eagle rods? Enough to make a noticable difference in how fast the revs come up?
Van
Van
gofastgeorge;1381358 said:A stock rod will be about 725-730 grams.
An Eagle is 615 grams.
