preparing for a rebuild chime in
BrandonW
1,300
N.J.
first off i have a question, they guy at toyota parts said i can still get the engine wire harness so is this what im looking for?
http://www.cygnusx1.net/Supra/Library/EPC/291220/catalog.aspx?F=8202&P=1
looks to be the bottom one
and secondly i have a few things already and if you guys want to chime in a add anything i should also get (im trying to get as much as possible aside from internals beforehand)
what i have so far
1: stone gasket set (will figure out what mhg to get when machining is done)
2: horseshoe gasket from toyota
3: 2 gaskets that go between the timing belt case and the block from toyota
4: new accordion hose from toyota
5: ngk spark plug wires
6: toyota oil pump
7: toyota fan shroud (already put that one for now)
8: apexi intake
9: ddp
10: bic test pipe
11: hks dragger exhaust
12: hopefully getting a new engine wire harness from toyota
13: i replaced the ps pump and water pump about a year ago but i might do that again just for peace of mind
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
oil pump shaft bearings
oil squirter bolts
new coupler for the TB (i bought a 4ply with t-bolt clamps)
if you have the money get all of the exhaust stuff ceramic coated.
new flywheel bolts
thats all i can think or right now...
BrandonW
1,300
N.J.
im going to see if there is any place in my area that does that
like for the head shields, exhaust manifold and my ddp
tbcmorris
SM Expert Thread Derailer
Mar 14, 2007
1,820
PRUVEN PERFORMANCE MILFORD CT
Arp head bolts. Valve cover gaskets if not included in the....they should be though. I can't think of anything else. Are you planning on tearing down the bottom end and building for more power, or just freshing up the motor?
BrandonW
1,300
N.J.
pretty much just freshing up the motor but i believe i will tear down the bottom end
my power goals are 300 - 350hp daily driver
which the stock internals will be ok with
BrandonW
1,300
N.J.
Poodles;1131381 said:
Keep some spare money set aside because there WILL be little crap that you'll find that need replacing...
haha oh i know that for sure
i had a great experience with the exterior which i did first because of some rust issues i wanted taken car of
just some other stuff that i needed here and there that i wasn't prepared for
thats why im just trying to get as much as i can so i don't get held up to much because once the engine is out eveything else will come out thats needed to paint the engine bay
i will be a experience im sure :D
