PowerbyDel Supra(MKIII) vs. nforce evolution
jt2ma71
Impeller Head
Washington State
Del won a thousand bucks on this race, his first race with the new setup. I am not sure which of my manifolds is installed on this car because he bought both styles. He promised to get me better quality videos as this one was at night and you can hardly see the cars. Sounds good though.
EDIT: It has the short runner manifold.
http://videos.streetfire.net/video/C268C8AB-B8FD-4AAF-BCE5-B893C08382D1.htm
jt2ma71
Impeller Head
Washington State
Here's a picture of the engine bay.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
I love how the hot IC pipe wraps around the intake. Nothing but hot air!
That's a very clean engine bay otherwise. Do you have pics of the entire car, Ron?
jt2ma71
Impeller Head
Washington State
There is probably very little difference in temp whether that pipe is routed down or up. The radiant heat from the header will heat it up anyway. The aluminum pipe helps dissipate heat faster so that helps. It is also before the IC, not like on the stock one where it goes up that way after the IC. Anyway, he will send me some specs and post better vidoes as soon as he can. Here's the car.
