Piston dish?
cuel
1,536
Baytown, Texas
I have a set of JE pistons, and the box says the dish is -.315. I'm guessing its in cubic inches, but not sure. I need to get a general idea of what cr these would be. The calculator I used said they'd be 5cc dish, which doesn't seem right.
Here's a pic of the tag on the box:
Thanks
88_7mge
N/A Lover
Dec 1, 2008
32
Hemet, CA
thats what i hate about companies like JE. Half the specs listed on that label are Imperial measurements and the other half are Metric. Since all the metric measurements are labeled with the units and all the imperial measurements are not, i believe they are measuring the dish in cubic inches.
cuel
1,536
Baytown, Texas
JE told me they're a custom piston, as their standard piston for a gte is -.185. They said they want the part number to tell me what they are.
I guess I'll go get some plexiglass and a cc dropper, and see if I can get a solid number. Thanks for the help all.
cuel
1,536
Baytown, Texas
Thanks Mark.
I had talked to JE(finally), and they told me the same, -29.5 cc, which would work out to around 7.5:1 with stock head and block dimensions, and a stock head gasket?
2jz88mk3
GVRA
Thanks
Didn't read much of the other posts =P but for what its worth 0.315 Cubic Inches is 5.16192516 cc
1 (cubic inch) = 16.387064 cc
Hope that helps
gofastgeorge
944
Texas
Most likely the .315 is a depth measurement from the top of the piston.
Stick a caliper on one, see if that is what it is.
