alright i have never done a compression test before and was looking at them to make sure my supra is still good... i have a couple question about them
1. the tester screws into the spark plug hole on the block correct?
2. Car is off correct?
3. i was looking at this one at sears
http://www.sears.com/sr/javasr/prod...tomotive+Testing+Equipment&BV_UseBVCookie=Yes
and do i need to hook a compressor to it? how does it test compression i would assume it needs to get air from somewhere.. if it does need a compressor could you just use a bike pump?
4. can you hurt your car by doing a compression test?
5. on that one from sears it says it fits 14 and 18mm size spark plugs will that fit our cars?
please dont flame me!
