I have a 1988 Supra single turbo, shut it off one day and then it would not start, tested and the fuel injectors are not firing, and it rolls over like it is out of time, timing belt is OK, any ideas????
bad wiring somewhere? since this is the standalone section....did you change any thing on the ecu before the no start? did you enable injectors on the ecu? I usually find it's the simple stuff that goes wrong if my car has been running for awhile and it just stops running.
