New Mk3 Owner
Mueller87
Norfolk VA
Hello everyone! my name is lucas, originally from Harrisburg PA now living in Norfolk VA. Been wanting a mk3 for longer than I can remember and finally got one. a 1987 Turbo hardtop, 5 speed. two tone silver/dark silver paint, light brown interior. paint is in rough shape but body is straight and hardly any rust. Got it for What i consider a steal at $900. but there is a catch. Car isnt running right now, and the fuel tank is lying on the deck underneath the car :icon_frow I have plans to tow it back to my place this saturday and when i get it back i'll be posting pictures. My plans for the car are a 'Rotisserie' type complete teardown and rebuild, bare-bones race type interior and cage, and a 500ish hp 7mgte build. got a lot of future purchases spinning in my head and a lot of choices to make before its all said and done. thanks for reading!
Supra NA-T
Total Annihilation
Nov 7, 2010
442
Leesville,La
meh, 900 for a non running car, get ready for a list of problems. none the less looking forward to seeing this restoration/build thread.
98BlakTacoma
67
Sterling
Welcome and hey whether you get the car up and running or not you should check out MRSO and the big meet M.A.Y. In may, there's a bunch of supra guys in VA beach, Norfolk, and Hampton areas and they are awesome guys
Sent from my SPH-D710 using Tapatalk 2
Mueller87
Norfolk VA
Im surprised to get any responses without picture update! and yeah I'm aware, but I've been at it for a while. never with supras but I'm prepared. Im sure ther'll be plenty of issues with the car but I've got an SV21 camry for a DD so no worries. More updates on SAT with Pics when I bring the car home. Thanks for the tip, 98Blak, I will definitely check it out (If work doesnt Interfere!)
Mueller87
Norfolk VA
Alright so I went and got the car saturday and when I got it back to my place I took some pictures but I was running a little late returning the trailer I borrowed so Sorry but for now there are only 4. many of the interior pieces are lying in the back, 2 extra wiring harnesses are in there too, with what I'm assuming is the original spare tire. There was still a battery in the car so today I charged it for a bit with my camry and All of the Lighting and electronics work perfectly. Seems like all of the bulbs are working too. headlight motors work fine. I havent posted pictures on a forum before so hopefully these links from imageshack work.
Hey be easy on me, it was only 900 dollars. Turbo/r154
Mueller87
Norfolk VA
Oh and I almost forgot. Look at the front plate "8 BDWSR" as in 8 Budweiser as in Dale Earnhardt Jr. ... The guy I got it from was really nice though and since it wasn't running a Bunch of his friends were around to help us Load it on the trailer.
RemzRR
15
Orlando
Did the seller give u any hints as to why its not running..?
Still a good deal and the body is in decent shape. If the motor is busted have you thought about any swaps 1JZ etc
Mueller87
Norfolk VA
He seemed to think it needed a fuel pump, so sure in fact that he tore into the floorpan above the fuel tank in the general vicinity of the fuel pump, somehow missing the fuel pump cover (assuming here) and then dropping the fuel tank out and disconnecting everything, even after the extra holes were hacked in the floor pan. So the fuel tank assembly is not installed now, but the engine cranks. He told me he sprayed ether into the intake and cranked it over and it wanted to start.
The odometer reads 23x,xxx right now. I am fairly certain that If I put a new fuel pump in it and did a minimal amount of troubleshooting It'd run just fine, assuming it doesn't have a blown head gasket. The car had to be very well taken care of prior to the past 2 or 3 owners (or at least for some time early on) by the looks of it, but the past few owners haven't treated it so nice.
Anyway, the first 'stage' of my plan is to tear everything apart, gut the whole interior, weld up the seems for stiffness, put in strut-tower-linking-all 4 corner-attaching-1,352,356 point-racing roll cage, put in a skid plate to keep the subframe off the deck, remove all of the suspension components, blast and coat what I can, replace what I can't, and put in new bushings and new anti-roll bars. Then get some kind of chassis liner/coating all wheather for the underside and fenderwells, some kind of lizard skin type coating for the engine bay and car interior.
In the mean time I want to break the engine open and see if its worth my while to refresh it. If it is, I'd keep it, rebuild with all new bearings, stock internals (except maybe new rods) minor head work, brian crower cams (not sure which stage yet, only because I'm not sure if I'd have to get some crazy pistons custom made as I'm not too knowledgeable on the 7M motors.) A 3" stainless exhaust, top-side-top-facing-up-visible-turbo exhaust manifold, Borg warner turbo aimed at 500hp or so, bigger intercooler blah blah blah as you can see thats getting preeeety expensive.
So I was thinking, I've been working on small block chevy's a lot longer than I have any kind of Toyota engines. I know swapping a GM engine that came out in 1955 isnt really the most respectable thing to do to a car as technologically advanced, unique, and iconic as a supra. But on the other hand, It was 900 dollars and I'm not sure if I care about that. Anyway, I figure I could get a 5.3 LS3 out of a newish chevy pickup, get it in the car and running for less than what the turbo that I would buy for the 7M would cost.
From there, I know what I'm doing, things are much simpler for me, and I'd only have to spend a fraction to make the same power. So that was kind of a long answer but basically I could go either way at this point, what I know now for sure is that I want to take it down to the shell and start from scratch. That'll give me time to research dependable 7M's since this would eventually become my DD while I overhaul the foundation. honestly I've got a lot of plans for it but I dont want to sit here and blow smoke when people can see those pictures of the car looking the way it does!!
Only time will tell and as soon as I find a place to rent and get it up on jackstands and start breaking it down I'll start taking pictures and open a build thread. I Am looking for any reccomendations of anything someone has done similar to any of the aspects I have described, I want to start talking to more guys on here because I dont know much about these MKIII's. Also need to get my posts up so I can become a part of the classifieds section. These Starion wheels won't get a second look just anywhere.
Mueller87
Norfolk VA
So I just went outside and took a few more pictures.
Heres my DD SV21 Camry and the Supra sitting outside
Here you can see where the floor pan was ripped open... Ouch!
Mueller87
Norfolk VA
Here's a few more.
Someone tell me this is a typo.... Is my car REALLY this heavy?!
Does anyone know what this paint Code is? or what the colors are called? Thanks for looking!
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
Looks like you have quite the project...
Pretty straight but needing a few things here and there... That's the vehicle weight rating not the scale weight but these cars are pretty heavy
Mueller87
Norfolk VA
Yep I definitely Have my work cut out for me here. But I was mostly looking for a hard top with a straight body. I got lucky on the turbo/5 speed combo. And the title I have for it says 3400 lbs, which seemed light to me compared to what I've read about these cars but When I saw that tag in the door jamb I was really surprised. Hopefully after I Get done with everything I want to do it isn't any heavier than 3400 lbs. I'd be happy with that.
