My car died in Dec and had a code 14. I figured its was my ecu again, (3rd in 8 years) so I sent it w/ my others to Driftmotion for repair. Now heres my problem, I plugged in one of the repaired ecus and the started and idled fine. I let it warm up and took it for a spin. When I came back I let the car sit and idle for 2 min the the idle started to bounce and it died. I now have a code 12 and 14. It seems that the car starts when cold but will die in a few min. I used my meter to check the cam/crank sensors and the #s I got seem to be in range of what I found on a mk4 tech site. All within 1040-1049 ohms cold. What should be my next step? My coils and plugs are new, and I tried my xtra igniter, so I "think" the code 12 is my main problem. Thanks for your time.
