Im starting to get to the point of starting and breaking in my 1jz motor and already started piecing my parts together to go single and make 470-520 whp, so first things first i already have a a Haltech PS2000 ecu system and was looking for some other parts to get to make this build as efficient and reliable as possible.
I have done some research and have seen some people running into spark blowout with the stock coils, so my idea is to go ahead and get some LS2 truck coils and run all 6 direct fire with the haltech, i have looked but i havn't seen anyone who makes a bracket for them on the 1JZ so could anyone could direct me to a place that does or advise on using another set of COP set up that is already out there.
Next im looking to get an automotive 400LPH with 80lb/850cc injectors so i can run e85 at those power levels to stave off detonation at while on the track then running 93 while on the road to hopefully return decent gas mileage.
I already have a big rad coming in with dual mishmoto fans and shroud and still have the BMW AUX pusher fan in front and going to get a bigger oil cooler soon so cooling shouldn't be an issue
I have decided to go with 2JZ cams for DD reasons and thinking about getting adjustable cam gears to get some overlap to produce more power without boost but i havent seen anyone adjust 2JZ cams on a 1JZ yet so im not sure.
I also want to go with a exhaust mounted crank case vent system to produce vacuum and improve efficiency of the motor but it shouldn't be enough to start creating damage
My main goal is to create a great mid to high range puncher that can be used everyday without a rebuild every 30k miles, the turbo im using is an PT6163 that i think should do the trick but have a feeling it might start to choke over the 500 hp range.
So just wanted to bounce some of these ideas off some of you who have ventured before me and if you could give me some tips or advice on what to do and not do. Also if you could help me find place to get all these pieces (mainly the LS2 brackets for the 1JZ)
PS. can anyone tell me what good realistic HP i can expect out of this motor on pump gas because im seeing big differences in number (from 450 all the way to 600 pump)
