na block, gte head?
Jeff Lange
Administrator
4,918
4
Calgary, Canada
jefflange.ca
No, that will not work, you will need to get oiling from the intake side of the block, oil pressure port or similar.
Also do not forget that with a GTE head you are going to need a crank position sensor, which may require a new oil pump, sensor, and timing pulley.
Jeff
