Can anyone enlighten me, I bought a 2jzgte soarer lexus motor and decided to do a swap into my 1991 Supra MKIII. I have converted the usual auto ecu and wiring to the us spec manual obd 1 ecu I purchased here locally and verified it came out of a 6 speed spec Supra MKIV and running. Here is the setup. Bosch 044 pump in the tank with #6 lines running from tank to hks fuel rail. Denso 720cc injectors and resistor box custom wired in. VPC with 680cc chip 6 speed manual. I am running R154 5 speed tranny. When it idles at cold it runs very rich and at warm up temp it runs fine but after 20 minutes running, I lose idle and it stalls until I disconnect battery and reset ecu. Boost is set at 15 psi. The car runs strong goes sideways in second gear when I get on it just a little more than one third throttle. I have heard a lot about the switch settings on the vpc and which wire to use. Can anyone bring some experience and knowledge to this for me. Thanks in Advance James
