mk3 1jzgte wiring questions
kyleh86
15
Phoenix Arizona
Is it possible to use the body harness connector from the 7mge engine side to wire the 1jz? If so has it been done before? And which pins need to be relocated to where?
Thank you all in advance for any help/guidance is much appreciated.
Car
1986.5 mk3
Engines
7mge blown rings
7mgte not enough power
1jz installing....
suprachris
33
fort wayne
During the whole process of swapping my 1j, I never knew about this site. Maybe I can now figure out why my neutral safety switch isn't working as it should.. thanks
