Max Boost from a Driftmotion 57 Trim Turbo???
CtownDawgs88
Doin' the Best I Can.....
Mar 23, 2009
46
Northern Ohio
CT 26 - granted i have the AEM boost controller and AEM ECU - so that can me configured.
Would you happen to know what the wastegate spring is set for - I'm thinking 8psi???
Any chance I could get to 18psi with my setup in the build link?
suprastroker88
Supra Tuner
Jul 16, 2008
453
Bay Area, CA
you can run 18psi. if im not mistaken, thats like the max for a 57trim ct. you need a bigger turbo for your setup bro. seems like youre built to handle some serious power
Being over built is a good thing.
I wouldnt go higher than 18psi. Iirc it does best at like 16 and then the efficiency starts dropping.
CtownDawgs88
Mar 23, 2009
46
Northern Ohio
Thanks for the replies - yea I prob will upgrade next winter to a T4 - Just unsure of what specs for that turbo.
Looking to get it running soon and break in this summer - then step it up.
