map ecu with 1jzgte
queenskid926
Tires yeling @ every Lite
Jul 27, 2007
1,112
New York City
I have the map ecu wired up and install and also loaded a few different base maps but i can not get the tps signal to work right, It is inverted. When my foot is off the throttle, it reads 100% and when it on all the way it reads 0. The total opposite. Is there a setting or something that i missed? It so, far everything is reading right rpm and able to make a good connection with the comp etc etc. I also tried to tap into other wires apart of the tps and still no change.
This is a soarer 1jzgte.
RockPaperSwoRD
I have aCustom User Title
Jul 26, 2008
392
SanAntonio
did you calibrate your tps signal input? Put your car key into the ON position but dont turn the car on. goto edit> ecu config and under TPS config. press i on the idle space. then floor it and press i on the maximum scale. try it and see if it worked.
