Map-Ecu "error initializing com port, check settings?"
emoFTW
OK
Little lost on what to do here. Can't connect my map-ecu to my laptop. Do I have to configure my usb to serial converter? the car came with one on there already. I'm running windows 7 on my laptop, and I'm trying to use Map-Cal v2.3
Any help is appreciated.
Lee
oldsking
789
Chapel Hill, NC
Yeah you need to make sure the driver is installed correctly first on your computer. Then go to your device manager and confirm which USB port you have on your laptop being used while plugged in and in te MapCal sotware you can choose which com port ( 1,2,3 etc) you are using.
