maft-pro + 780cc injectors
black91turbo
Formerly black87turbo
Apr 27, 2006
1,064
Jacksonville, FL
can the maft-pro support these? meaning would i have to run sequential injection or anything to get it to idle normally with these injectors or can I just pull fuel as I regularly would with my 550s?
FullNelson
574
Coastal Georgia
If I remeber right you can. You would just take the difference between the stock 440s and 780s. 77.27% bigger, So you would decrease your fuel tables by that much. Someone correct me if im wrong as this is all off memory of what i've read.
drjonez
the motor city
www.4cefed.com
Yikes.
Sure, you can do that, but realize the change in timing is going to be HUGE. You'll really have to dial back the advance to keep things in line.....or run C16 every day and keep the boost reasonable.
To the OP- As I've always said, if you're looking at injectors that big, you should be thinking about a standalone.
