I've read so many different things on this topic and am lost. Here's my current state:
I blew a piston in old 7MGTE. Rebuilt it with forged internals, upgraded CT-26 to 57 trim, have 550 cc injectors, 255 walbro pump, AFPR, Maft Gen 2, lexus AFM, ect.
I owned the car for many years prior to rebuild and it always ran great.
I've got everything hooked up...and I am very confident all the wiring is good and correct.
Maft settings are for MKIII supra, 3 liter, MAF in/output are both MKIII supra, everthing else is where it was when I plugged the unit in. From what I've read in many places, fuel pressure should be set around 40 psi with vacuum line off. Mine drops to about 33 with vacuum line on. Vacuum in car is reading between around 18 or 19 in hg.
I've tried to adjust mainscale and it seems to change nothing. AF ratio's don't change at all. -20% is what I believe it should be set at based on my injector size.
So, with fuel pressure at setting described above, Gen 2 mainscale (even though it's not doing anything) is at -20%, my AF ratio is basically pegged at 22.4. If I bump fuel pressure WAY up, I can get AF to maybe 15.7 but no richer. I'm pretty sure bumping the fuel pressure up that high is not the answer though.
I've also been monitoring VF on Tuner Pro and it does not change from 0 to .1. I am only trying to get idle set up first, then I will attempt to tune under load.
Can anyone give some insight? I can't be the only one ever to have this happen.
On a side note, if I were to drive this car (when I bump up the fuel pressure), it has terrible power, chugs up under load like it's missing. Have changed and tested plugs, injectors, wires, coils, checked CPS many times. MAN! Just want to drive the beast!:: angry ::
