Looking on how to inprove 0-60 in a mkIII 1992
Agentorange00
Ride hard and get off.
Feb 9, 2010
New York
i was told the stock 0-60 is 6.4sec what are some easy cheep ways to make this a little faster. I could care less about the top speed as long as it could still 130.
supramk3speed
305
Texas
Obviously traction arms and stickier tires for starters, just look around on here. There is plenty of info on how to improve your zero to 60 times.
supramk3speed
305
Texas
In my case i was getting loose with a stock engine through first and second with a few third gear chirps. Not good for 0-60's. Get a feel for your car, you will get a good idea of what it needs to run fast down low.
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
Is your Supra turbo? Mods? First thing I'd do is get some good wide tires (275/40-17 is what I run in the rear). If you can weld you can beef up your traction arms like I did. I'd also replace your suspension bushings with some nice poly bushings. Making power is always the first thing that is key to make a faster 0-60 time, then once you don't have traction you need to address that issue.
Agentorange00
Feb 9, 2010
New York
ok thanks but that 300 shot of Nos i dont think the car will be doing even 1mph after a fue shots of that, that shits like heroine.
