Looking for help with tires
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I just went to the dragstrip for this first time friday.
13.9 @ 123 MPH :nono: I'm a terrible driver
I'm in need of some traction, and in need of help..
info on my car: 600+whp, weekend car, ~200 miles a week.
What do you guys think:
Drag radials on sawblades-
PROS
-beefier sidewalls
CONS
-not very wide
Drag radials on 17X10's-
PROS
-Wider than sawblades
-Car looks good at track
CONS
-Treadware = waste of rubber on the road
Full slicks- (not worth putting on sawblades are they??)
PROS
-traction!!!
CONS
-Gotta get skinnies up front
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
What are you running currently?
Do you want a set of wheels/tires that are on all the time, or do you want a dedicated setup for drag usage?
Just want to make sure i have everything clear before i offer a suggestion :)
chevyeater
wastegate hose is pulled
Long Island, NY
PROS
-beefier sidewalls
Good for highway roll-ons
CONS
-not very wide
Going to shock load driveline and break stuff
PROS
CONS
Meh, same as DRs on sawblades aside from looks and a bit less sidewall for even more driveline shock.
PROS
-traction!!!
CONS
Also not street legal.
I'd say get some ET street bias plies for the sawblades or RX7 wheels (skinnies up front) and get some pimp wheels for the street with drag radials on them. That is what most people around here do. You can still put the ET streets on if you have a dig race on the street and you will have enough traction for 2nd gear roll ons with the pimp wheels and DRs.
BTW, what was your 60' time on the 13.9? 3.0?
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Thanks for the suggestions :)
I can't recall my 60', timeslip is in the car. I believe it was ~2.7 :biglaugh:
chevyeater
Long Island, NY
hottscennessey;990235 said:
I'm currently running Falken Azenis 275 45 17 front, 275 40 17 rear.
I had those on my SC. They handled great but were completely worthless for straight line traction. I'd regularly spin 3rd gear on the street with only ~450 hp. I did manage a 12.7 with them (2.1 60') at the track though.
89turbotoy
2 89 supras 2jzgte/single
Jul 30, 2006
309
cincinnati
what clutch are you running? to get a good launch you have to slip it just like regular driving only @ launch rpm. do that with the dr on you sawblade and you'll get sub 2. 60ft (if u do it right)
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Os Giken quad disc, the most impossible clutch to slip... evar :aigo:
89turbotoy
Jul 30, 2006
309
cincinnati
yeah that is a problem, it is gonna be hard to get ur 60 down without slipping ur clutch. you could always narrow a ford 9 inch, tub the car and put in a 4 link and slicks and skinnies so u dont have to slip.
Slow66
Apr 3, 2005
1,457
Newington, CT
I agree w/ Brian(chevyeater).
Get some 26x10.5x16 ET streets for the sawblades, and find some used 15x4 Draglites (all over the place!) and then get a new set of M/T ET fronts (less than $100 each IIRC). Fairly economical, and it will WORK! :)
Slow66
Apr 3, 2005
1,457
Newington, CT
Just going off memory, but i think they were 2.25 bs. You'll need a 3/8" spacer to clear the caliper though. That's just due to the design of the Draglite though, not necessarily the backspacing...
carfreak987
7
Indiana
I agree that a good clutch is essential. I would also be interested in knowing what clutch you are running? Please inform and I will see what I can do.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Dude... this thread was revived from 2.5 years ago??
On topic... I don't slip the clutch using full slicks on sawblades. Just let the boost climb to ~7psi, then dump the thing and HANG ON.
