these are my settings..sorry i cant get tuner pro to connect to vista...idk if i have it set up wrong,in full density mode it idles ok decent respnse,in hybrid density idles good but bad respnse
config-
vehicle, 0
cylinder, 6
disp, 3.0
air flow, speed density
map, 3 bar
load srce, use map
baro mode, @ sealevel
fout, supra mk3
vout1, map 3bar gm
vout2, map 3bar gm
afr source, aem gauge
fin mode, supra mk3
aux1, +v to trig aux
flow error mode, sd/tuned
system-
mainscale, -.5
vout1 max, 2.560
vout2 max, 4.000
afterstart 4.0
lo load pt, 32.5
mi load pt, 100.1
hi load pt, 143
fout max, 0
tm base, +.5
tm correct, 1.20
af tr delay, 0.0
fe smooth, 30
use ve table 1
spark base, 13
pt tracking-
idle tps, .200
idle rpm, 800
idle afr, 13.5
cruise tps, .000
cruise rpm, 2560
cruise load, 91.0
cruise a/f, 14.5
lean load, 84.5
lean delay, 10.0
lean a/f, 16.0
gain, 15.0
enable delay, 95
etps rpm, 4800
etps load, 166.4
tune resp-
tps enrich, 1.15
tps decay, .60
tb size, 7
tps map max, 104.0
map enrich, .10
bst enrich, .10
map tps min, .800
map rpm min, 2560
maf lim tps, .000
maf lim, .0
maf krpm, .0
lim min rpm, 0
lim time, .0
spark wot/spark aux @ rpm-
2000, 13.0
2500, 13.0
3000, 13.0
3500, 13.0
4000, 13.0
4500, 13.0
5000, 13.0
5500, 13.0
6000, 13.0
6500, 13.0
7000, 13.0
7500, 13.0
8000, 13.0
low,mid,hi load @rpm -
400, 0
800, 0
1200, 0
1600, 0
2200, 0
2800, 0
3400, 0
4000, 0
4600, 0
5200, 0
5800, 0
6400, 0
7000, 0
7600, 0
air temp-
-40, 0%
13f, 0%
41f, 0%
62f, 0%
82f, 0%
103f, 0%
129f, 0%
173f, 0%
212f, 0%
@aux trig-
400, 0%
800, 0%
1200, 0%
1600, 0%
2200, 0%
2800, 0%
3400, 0%
4000, 0%
4600, 0%
5200, 0%
5800, 0%
6400, 0%
7000, 0%
7600, 0%
boost(dont have the mpro bc,have the greddy pro spec b II)
tps spool, 2.5
rpm spool, 2400
tps start, 3.7
psi start, 5.0
dc% start, 10.0
psi set, 10.0
psi aux, 10.0
gain, 4.0
dc% start aux, 10.00
max rpm, 0
afr tracking-
min tps, 4.9
min rpm- 3200
min load, 166.6
lean lim%, 11.5
rich lim%, 10.0
gain, 4.0
afr
2000 - 8000rpm, 11.5
aux%, 0
config-
vehicle, 0
cylinder, 6
disp, 3.0
map, 3 bar
load srce, use map
fout, supra mk3
vout1, map 3bar gm
vout2, map 3bar gm
fin mode, supra mk3
system-
mainscale, -.5
vout1 max, 2.560
vout2 max, 4.000
afterstart 4.0
lo load pt, 32.5
mi load pt, 100.1
hi load pt, 143
fout max, 0
tm base, +.5
tm correct, 1.20
af tr delay, 0.0
fe smooth, 30
use ve table 1
spark base, 13
pt tracking-
idle tps, .200
idle rpm, 800
idle afr, 13.5
cruise tps, .000
cruise rpm, 2560
cruise load, 91.0
cruise a/f, 14.5
lean load, 84.5
lean delay, 10.0
lean a/f, 16.0
gain, 15.0
enable delay, 95
etps rpm, 4800
etps load, 166.4
tune resp-
tps enrich, 1.15
tps decay, .60
tb size, 7
tps map max, 104.0
map enrich, .10
bst enrich, .10
map tps min, .800
map rpm min, 2560
maf lim tps, .000
maf lim, .0
maf krpm, .0
lim min rpm, 0
lim time, .0
2000, 13.0
2500, 13.0
3000, 13.0
3500, 13.0
4000, 13.0
4500, 13.0
5000, 13.0
5500, 13.0
6000, 13.0
6500, 13.0
7000, 13.0
7500, 13.0
8000, 13.0
400, 0
800, 0
1200, 0
1600, 0
2200, 0
2800, 0
3400, 0
4000, 0
4600, 0
5200, 0
5800, 0
6400, 0
7000, 0
7600, 0
air temp-
-40, 0%
13f, 0%
41f, 0%
62f, 0%
82f, 0%
103f, 0%
129f, 0%
173f, 0%
212f, 0%
@aux trig-
400, 0%
800, 0%
1200, 0%
1600, 0%
2200, 0%
2800, 0%
3400, 0%
4000, 0%
4600, 0%
5200, 0%
5800, 0%
6400, 0%
7000, 0%
7600, 0%
tps spool, 2.5
rpm spool, 2400
tps start, 3.7
psi start, 5.0
dc% start, 10.0
psi set, 10.0
psi aux, 10.0
gain, 4.0
max rpm, 0
afr tracking-
min tps, 4.9
min rpm- 3200
min load, 166.6
lean lim%, 11.5
rich lim%, 10.0
gain, 4.0
afr
aux%, 0
