Limit of the boost level On stock ecu
juan jz
197
Anaheim
I need help, I'm trying to set up my cars boost level so I can take it in to get tuned, I want to know the limit of stock ecu before it hits fuel cut. I'm using safc II
nick88
JayHall's Hero
May 10, 2009
794
Des Moines, Iowa, United States
right under fuel cut, it can be different on different elevations and how cold or hot it is that day. My friend has a 57 trim turbo on the stock injectors and hits fuel cut around 9 psi on a hot day.
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
are you on stock injectors? with my fuel pressure cranked way up and a tune with a safc2 i was able to run 18 psi without a problem for dyno numbers
juan jz
197
Anaheim
I'm running 440, I started cranking up the boost to 14psi but it would hit fuel cut at full throttle, so I have it at 12 and is pulling hard all the way through, I'm going to start looking into upgrading ecu, what do u guys suggest? Aem would obvious be the way to go but I'm leaning toward mines ecu since I'm on low budget at the moment
