Knock Sensor Q...
mk3_dude
Boost Master
May 10, 2005
265
Arkansas
Currently, my 7M is cranking but will not turn over to start.
Both of my Knock sensors are unplugged because the wires are crumpled to pieces.
Without these two knock sensors connected,
will this cause my car to not start?
quake
toyota tech
Apr 13, 2005
619
r.i.
no
shaeff
Kurt is FTMFW x2!!!!
9
Around
no, it should start and run fine. you'll have no acceleration, code 52, and poor gas mileage, as when code 52 is registered in the ECU, timing is retarded, and fuel is added. if you're turbo, your car will hate boost.
supraslo
Slaying Cobras
Jul 29, 2007
53
Burlington NC
knock sensor wires are common to become brittle hence the reason why alot of dealerships replaced them for free back in the day, but even the replaced wires do not last forever. buy some shielded wire from radio shack and SOLDER at the ecu and knock sensor connector. this will eliminate knock sensor problems from bad wires. As far as the no start, start looking at something else.
survyor2
171
West Palm Beach, Florida, United States
Question: Do knock sensors have to be grounded?
I had code 52. I rewired both sensors with the coaxial cable. I still had code 52. I got a used knock sensor from a working car. I unplugged the front connector and plugged it into the "new" knock sensor. The sensor was just hanging out in space. I still got code 52. I repeated the step for the rear connector and still got code 52. I was trying to rule out which sensor is bad. Any ideas?
Dennis
