Jdm swap need help!
MHD_88
El Paso
I just swapped my 88 mk3 supra turbo 5speed with a jdm 7mgte. I think the engine is a pre 89 because of the green cps plug. I swapped the motor and extended the harness and plugged everything in. When i first tried to crank it the starter nor the fuel pump turned on. On my dash I have a antilock light on as well, I don't know if anything has to do with it. I don't know if it might be a ground or a fuse or something else. Please send me suggestions as to why it isn't starting!
MHD_88
El Paso
Yes I am using a yellow plug harness and last time I tried to check for engine codes none came up
Drifting in mexico?
if the car was turbo why not use the harness that came in the car instead of extending the jdm harness.
no abs in japan either. better off using a us harness
I would recheck all your wiring with a ohm meter. You will also have to run the 3 wires for the rear abs sensor for that light but check the abs codes to make sure
