Matt - Well you just got to experience first hand why a lot of people think a thicker oil is best.  I can assure you it is not...not using a 20W-50 has no impact on developing rod knock.  This guy is basically talking out of his arse
People will point at the Supra manual oil chart and tell you a 20W-50 is recommended.  It is one of the oils listed, but they don't tell you it's just ONE option available.  Take a look at the chart:
Note that 20W-50 is listed for a 10 to 100+ F temp range...so is a 15W-40 and 20W-40.  On the 2nd line a 10W-30, 10W-40, and 10W-50 are listed for 0 to 100+ F temps...a wider temperature range.  Also, if you look at the verbiage at the top, the manual shows API grades SF, SF/CC, and SG...all are obsolete API grades...you cannot even buy these oils anymore.  The current API grades are SL and SM...these oils represent a quantum leap in formulation improvements over the oils available when the Supra manual was published.  Modern oil's at SAE viscosity 0W-20, 5W-20, 0W-30 and 5W-30 easily cover the temp ranges (especially in cold climates) most of us operate the motor at...oils have simply improved that much over the last 20 years.  Bottom line:  Take the Supra manual oil chart with a grain of salt.
Your local Supra mechanic is not lying to you...he just doesn't know what he doesn't know and the previous owner of the car believed him
Here's what you hear from the guys that tell you to run a 20W-50 in the 7M:
1) The manual recommends it -
False
See above.  The manual does not specifically recommend a 20W-50...it's just one of the oils listed that are "approved".  It also recommends a 10W-30...an oil that covers a wider temp range.  Completely ignores that API SF and SG grades are obsolete.
2) A thicker oil will keep the bearings from getting hammered; provides a cushion between the bearing and crank journal/rod end -
False
Main and rod bearings operate in the hydrodynamic lubrication region.  I'll forego the technical explanation...think of it like a water ski.  The rotating motion "floats" the bearing between the rod end and journal clearances...the bearing never touches.  Almost every motor from the 1980's was designed with bearing clearances to run with an oil at 10-11 cst at operating temp.  That viscosity is smack in the middle of a 30W range at 210 deg F...just below the 195 deg F the 7M is designed for.
3) A 20W-50 will increase oil pressure and keep the bearings from touching the crank journal/rod end -
False
A thicker oil will increase oil pressure in the 7M, but only to a point.  The design of the 7M has the oil relief valve set at 63-71 psi...over this oil is simply routed back to the pan.  More importantly, the oil cooler valve on the stock filter head operates at 40 psi and you have a controlled "leak" from the oil squirters on a turbo motor.  Pressure is resistance to flow...a 20W-50's increase in pressure means that it does not flow as well through the bearings or to the top of the motor.  Considering a 20W-50 oil is 3-4 times thicker cold than a 5W-30, it's significant.  This means a couple of things:
- On a cold start, you will have restricted oil flow where you need it the most.
- The oil relief valve will cut the flow further by opening at the higher pressure and dumping oil back into the pan.
- It will take longer for the oil to get to the cam shafts...the small diameter hole in the middle does not facilitate flowing high viscosity oil.  Since the oil flows from front to rear on the cam shafts, it is going to take the #6 cylinder valves the longest to get the oil flow needed.
- The oil squirters spray pattern on the cylinder walls will degrade with a high viscosity oil...especially cold.  It's simple...higher viscosity, lower velocity.
Oil pressure has little to do with the way an open bearing (like rod & main bearings) works.  Like I said, these bearings depend on hydrodynamic lubrication to function...saying increased pressure will improve this is a very basic misunderstanding of how the bearings really work.  The ONLY time I could see using a 20W-50 from a bearing standpoint is if you've built the motor for it by opening up the bearing clearances to get the flow...you will see some very experienced engine builders do this, mostly on race cars that get re-built every season anyway.
4) Thicker oil "stays put"...it will stay in the bearings and on the valve shims after you shut down the engine -
False
When a 50w oil is at operating temp, it thins out just like every other oil does...just less so.  It has a viscosity of 16-22 cst, approx 50% more than a 30W does at operating temp.  This is not near enough to make the oil "stay put" when you shut down a motor at operating temp...it will drain from the top of the motor and from the bearings just like any other oil does (isn't gravity a bitch).  What is important is to get oil back where it's needed, especially cold...this is where a 0W-30 or 5W-30 is far superior...much better flow means the oil will get there fast.
5) A 20W-50 handles heat better and resists breakdown -
False
Any modern motor oil does an excellent job of resisting heat breakdown regardless of weight.  Oil and the additives in it are very stable to well over 250 deg F...if you see those kind of temps in a 7M oil system, you have a lot bigger problem to deal with.  Since a thinner oil flows much better, it also does a better job of keeping the bearings cool...another major function of oil in any motor.
The same folks that promote a 20W-50 will also say that a 0W-30 is "way too thin"...again, a basic ignorance about oil grades and what the numbers on the bottle mean.  Always remember the 1st number (0w in this case) means what the viscosity is "cold" at 40 deg C...the 2nd number is what the viscosity is "hot" at 100 deg C.  A 0W-30 is not thin, the German Castrol 0W-30 I recommended to you a while back is an excellent case in point...at 100 deg C it has a viscosity of 12.1 cst.  A 40W oil viscosity starts at 12.5 cst on the SAE charts...the German Castrol is pretty close to a 40W oil at operating temp.  The beauty about this oil is it also flows quite well cold and is Group IV PAO based...if you want to read more, I did a write-up on it in this thread, post #4:
http://www.supramania.com/forums/showthread.php?t=38768
Like JJ has told me many, many times...telling folks that a 20W-50 is not an optimum oil to use in the 7M is like "shoveling sand against the surf".  The reason is what you heard from your local Supra guru...the misinformation and ignorance on how an oil works keeps getting passed along via word of mouth...mechanics are the #1 perpetuators of this myth.  In all fairness, there are a very few instances where a heavier weight oil is called for...if the motor is built for it or if you already have worn bearings (just putting off the obvious here).  Also, a 20W-50 is not going to kill your motor off the bat...it's also not what's best for it either.  Plus, gas mileage will suffer using a thick oil.  In 99% of the cases where you have a healthy motor, a 0W-30 or 5W-30 will do a better job....especially if you happen to live in the northern tier of the US or any other climate where below freezing temps are common.
I changed the title of this thread...I welcome any and all comments.  Just a warning though, if you say "I've been using a 20W-50 with no problem"...my answer is going to be simple.  Of course you can...it's just not what's best for your motor and you need to educate yourself as to the reasons why you use it.   I base my reasons on the facts...do you base your reason on hearsay without knowing why?  Might want to think about it before you respond
