Hi all,
I am currently installing poly bushings through out my control arms rear first then the front. I have a question regarding inspecting the ball joints (upper control arm). What is the proper procedure for checking the turning torque. I followed this from the TSRM.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=RA&P=67
note: my 92 manual I own states 9-30 ft-lbs. that is quite a typo:nono:
Can someone clarify when the ball joint is bad? I am taking this spec to read that the ball joint should not take more than 30 in-lbs of torque to turn. Also the boot oozes out some grease out of the top as you move the stud back and forth. I think that when the joint is torqued down it would seal against the face of the arm. is that right?
