ignition color cable
fergsm
Puerto Rico
hi i need help, i need to know what is the color secuence on the ingnition of a supra 88
tis is the 4 cable that conect to the ignition in the left side of the motor there is green, yellow, black, light brown and the plug is green but it brake and all the cable are like mess. someone can tell me how. i can post a picture to show what i talking about!!
ogre
Car Junkie
Oct 17, 2009
86
wendell, NC
Is this what you were looking for...
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Ignition 2 Black/Orange Ignition Switch Harness
Accessory Pink/Blue Ignition Switch Harness
Tach Black Check Connector, Driver's Shock/Strut Tower
Brake Switch Green/White Brake Switch
Trunk Pin n/a Works with Dome Light
Parking Lights Green Driver's Kick Panel
Head Lamp Purple/White (-) And Green/Red (-) at Steering Column
Factory Disarm Purple/Yellow (-) Driver's Kick Panel
Door Trigger Red/White (-) Driver's Kick Panel
Door Lock Green/Yellow (-) Driver's Kick Panel
Door Unlock Blue/Black (-)
Horn Wire Blue/Red (-) Steering Column
