How to tell if my car is pre-89 or later.
Tysan
Lexington, NC
How can I tell if my car is pre-89 0r later. I checked behind the glove box and see that the plugs are grey in color. Help would be highly appreciated. Thxwire harness.jpg
Tysan
Lexington, NC
suprasick;1943584 said:
On the driver side, open the door and there will be a date code where the door jam is.
This is a pic of my car and this is what it says on my door jam. Im assuming its a pre-89, correct me if im wrong. If so, what yr wire harness and ecu should I get?
Tysan
Lexington, NC
What harnesses would I need. I have a yellow plug 86-88 wire harness and a grey plug 89+ wire harness. Would there be anything else I need?
Alang
55
Las Vegas
Be alert to early 89 builds. I had an 89 model donor car and found that it was mostly 88. 88 HAC sensor is an addon while true 89 HAC sensors are part of the ECU. The 90 TSRM diagnostic codes did not distinguish this but an 87 TSRM code would.
